Inventor Forum
"Sketch Blocks" in Vault
3 REPLIES 3
637 Views, 3 Replies
Every day I use a number of sketch blocks to created sheet metal parts. When I check these parts into Vault I would like to be able to search where that sketch block was used over time. My sketch block is named, "LIGHT SHROUD". Is there a way to search Vault for a sketch block use?
Thank you for any help.
3 REPLIES 3
cbenner
@Anonymous
Hi.... I'm not certain about sketch blocks, but I tried this with an AutoCAD block and it worked, so... what can it hurt?  In Vault Project Explorer, use ctrl-F or go to Tools\Find.  On the Basic Tab put in your block name.  I put a star on both sides just to catch anything close as well, like *LIGHT SHROUD*.  On the advanced tab, you can add criteria to narrow the results.  Try Property "File Extesions", Condition "is", and type ipt in the value.  Not .ipt, just ipt.  Hit add to add the search criteria, and then hit Find Now.  Hopefully that works.  I don't use sketch blocks, so I can't test it out.
Good luck!
johnsonshiue
Hi! I don't believe Vault can do that at the moment. Finding sketch blocks is not much different than finding a feature within a part. This is a CAD function, which is not a PDM function.
If you are Inventor API savvy, you might be able to write an iLogic rule or VB.net code to do that.
Many thanks!
Software Test Engineer
in reply to: johnsonshiue
Thank you
Technology Administrators
