Inventor Forum
"Shell" command problem, "Cannot find vertex"
4 REPLIES 4
nyrkkanm
552 Views, 4 Replies
I recently created a part in Inventor 2020 and I am running into issues using shell to finish it off. The part is a nose cone that was created using surfaces and then sculpt. These steps resulted in a solid part, but I obviously need to hollow it out so it is able to fit around the vehicle. When I try to use "shell" and select the faces I want to remove, it returns an error saying "The attempted shell operation was unable to solve for a vertex". I have spent hours trying to figure a solution, but can't seem to figure it out. I have attached the file I am referencing.
4 REPLIES 4
Xun.Zhang
in reply to: nyrkkanm
Howdy @nyrkkanm I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Yes, this is impacted by the geometry that Multi-line vertex, let me investigate it a little bit and try to provide a solution then.
Xun
nyrkkanm
UPDATE: I attempted to solve this problem by simplifying a lot of the sketches and features, but I am getting the same error. I would appreciate any suggestions! I attached the new file below.
Xun.Zhang
Hello @nyrkkanm,
Have several tries, nut not able to do the shell as well as surface thicken.
This is a modeling error case that several curve contribute to a vertex, suggest to rebuild the surface a little bit.
Or try to create a hole in that vertex and you can complete shell a little bit as below enclosed file.
Xun
nyrkkanm
in reply to: Xun.Zhang
Thanks for the help! So I am able to figure this out in the future, what was the function of the small hole up front?
Technology Administrators
