"Active Window On Save" As Default Option
cstarker6VCG4
cstarker6VCG4
How do I set Save Preview Picture = Active Window on Save as the default?
swalton
I believe that is controlled on a per-file basis.
Try editing your template files.  That should change it for all new models.
Changing your existing files may require a manual step, or an iLogic script.
Check on the customization forum to see if someone has posted a something to get you started.
Steve Walton
Inventor 2025
Vault Professional 2025
cstarker6VCG4
Me: "This setting needs to be default at the application level because we (like everyone) have hundreds of files."
Reply: "This setting can be applied at the file level."
Me: *bangs head on desk*
The point was missed. This is a design flaw. Why would anyone want some arbitrary obscured orientation to supply the thumbnail?
