Loft not blending
Loft not blending
mark.martinezECRPT
Loft not blending
mark.martinezECRPT
I am using Inventor 2023.  I am trying to create a wedge on a curved surface, but lofting creates seams.  Sheet 1 is what I want. Sheet 2 is what I get.  Sheet 3 are my sketches and center rail.  Sheet 4 is the command.  BTW sheet 1 was imported from our old CAD system as a STEP file.
CCarreiras
Hi!
Try this:
1-Select this face,
2-Use DELETE FACE: "Solid mode" disable and select "HEAL REMAINNING FACES"... Hit OK
CCarreiras
CCarreiras
Have you tried the "merge tangent faces"?
CCarreiras
mark.martinezECRPT
Thanks that worked.  I also found Replace Face also works.
CCarreiras
and also DIRECT Delete should work...
CCarreiras
