Hi. I have drawn a building, which has many lines when I zoom out. How do I make these lines as thin as possible?
You can open the style management window and change the line weight to the minimum.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
@Alexander_Chernikov , let's start with the below drawing.
I used the Inventor Reset Utility.
Changing the line weight in Styles Editor -> Layers -> 3D Sketch Geometry (ANSI) had no visible effect. Additionally, updating styles had no effect.
However, selecting Display true line weights in Application Options -> Drawing -> Line Weight Display -> Settings... resulted in the following drawing.
Why did this latter approach work while the former approach did not? Neither approach seems to affect a drawing printed to a file in PDF format. What are the best approach for display in Inventor, display of a PDF file, and printing?
Visible and Visible Narrow layers are used for the object line, not 3d sketch.
Have you tried Application options > Drawing > and near the bottom just un-checking the Display line weights?
And then also while printing remove object line weights.. I obviously dont know what all line type settings you have, just some options to play with.
