How do I make all lines in a drawing as thin as possible?
thomas.lever
thomas.lever
Hi. I have drawn a building, which has many lines when I zoom out. How do I make these lines as thin as possible?
Alexander_Chernikov
You can open the style management window and change the line weight to the minimum.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
thomas.lever
@Alexander_Chernikov , let's start with the below drawing.
I used the Inventor Reset Utility.
Changing the line weight in Styles Editor -> Layers -> 3D Sketch Geometry (ANSI) had no visible effect. Additionally, updating styles had no effect.
However, selecting Display true line weights in Application Options -> Drawing -> Line Weight Display -> Settings... resulted in the following drawing.
Why did this latter approach work while the former approach did not? Neither approach seems to affect a drawing printed to a file in PDF format. What are the best approach for display in Inventor, display of a PDF file, and printing?
blandb
Visible and Visible Narrow layers are used for the object line, not 3d sketch.
Have you tried Application options > Drawing > and near the bottom just un-checking the Display line weights?
Autodesk Certified Professional
blandb
And then also while printing remove object line weights.. I obviously dont know what all line type settings you have, just some options to play with.
