Inventor Forum
Question for the "Task Scheduler" creators
4 REPLIES 4
360 Views, 4 Replies
I'm trying to print files to pdf using Task Scheduler (I have more than 13.000 files to print), when I select the files that I want it says that I've reached the max amount of files selected. What is the exact limit number it has?
If the limit is close to 5-6k then it's ok, I can do this in 2-3 runs, but if the limit is 100-200 then what shall I do in this case?
Vadim Ferreira
4 REPLIES 4
johnsonshiue
Hi! There isn't any preset limit. As long as you have enough RAM to handle the task, it should be fine. Make sure you use a dedicated machine to do the task. Also make sure you turn on multi-processing in the Options.
Many thanks!
Software Test Engineer
in reply to: johnsonshiue
Then what is this? Am I doing something wrong here?
Look, all of my files look like this, all I want is that this page simply converts to pdf, nothing more. I don't see what's the problem with the Task Scheduler, it always gives me dumb errors...
Nevermind, the problem was with my station, somehow I lost license on my Inventor but it's all good now. Thanks.
Vadim Ferreira
