Inventor Forum
QTY, Unit QTY, Base QTY differences
2 REPLIES 2
Mark_Geurds
453 Views, 2 Replies
Hello All,
I'm experiencing some issues with different kinds of QTY's.
I've created an assembly with 2 instances of the same tube. They're unique parts, both adaptive and shown in my partslist on the drawing. so far so good. When inserting the partslist i've noticed something strange happened (see attaced image). My tubes should be 182,0 and 180,0mm. Yet when only showing the QTY column both show 182,0mm. When i add the 'other' qty columns they show the correct data. I've updated and rebuild all but still the value in the bottom row QTY column remains 182 instead of the correct 180. What am I missing? thnx in advance
Labels (1)
2 REPLIES 2
Mark_Geurds
in reply to: Mark_Geurds
Extra info, after closing and reopening the 'QTY' shows the correct data.
johnsonshiue
Hi Mark,
This sounds like a bug to me. If you can reproduce the behavior, please share the files and steps with me directly johnson.shiue@autodesk.com. I suspect there was a lack of BOM update operation.
Many thanks!
Software Test Engineer
