Recently having created various inventor ipt and idw drawings and not realizing that it is better to create a project ipj
file first i would now like to move these file into the project but how is this possible ? do i rename them all into the new project,can i drag them into the new project using explorer,what is the best way.
Regards
First, a question. Do you use Vault or any similar software?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Martin,
I am assuming you are getting when you open these files a message that comes up saying these files are not in the working folder. The working folder is set within the MP file. You should be ok in just moving them using Windows Explorer. Then once moved you wont see that message any more.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Scott
Thanks for the advice, i am pretty sure that i tried this, however i will give it another go,i suppose that the alternative is to generate a new project and re-create the assy drawing using the ipt parts.
Regards
As long as the parts did not change name you can copy the parts, assembly, and drawings to a new project folder.
Then in the project manager, create a new project, name it, and choose the directory where you put the files as the projects directory.
Then activate the project (if not already active)
Now you should be able to open your assembly, parts, and drawings with no problems.
T.S.
