Inventor Forum
Put symbol & in content center family table
9 REPLIES 9
Message 1 of 10
zakwanZKAWA
242 Views, 9 Replies
Hi, I wanna put symbol '&' in my family table but its doesn't appear. So, is there any solution to make the symbol '&' available?
a) I want to make the table appear like this:-
b) But it appear like this:-
9 REPLIES 9
Message 2 of 10
andrewiv
in reply to: zakwanZKAWA
Does it work if you enclose the entire string in quotes?
Andrew In’t Veld
Designer
Message 3 of 10
dave.cutting
It's a control character within content centre, so it can't be used anywhere.
Dave Cutting
Message 4 of 10
zakwanZKAWA
in reply to: andrewiv
Nope. It still doesn't show the symbol
Message 5 of 10
zakwanZKAWA
in reply to: dave.cutting
So, does it mean it is not possible to put symbol & in the family table?
Message 6 of 10
James_Willo
If you don't use column properties you can just type it in to each cell.
I think it's because you're in the field where you create an expression and you just want a text string.
James W
Inventor UX Designer
Message 7 of 10
James_Willo
Even quicker way is to just edit with excel and you can copy paste it to all the cells.
James W
Message 8 of 10
zakwanZKAWA
in reply to: James_Willo
Hi thank you for the reply!
I had done the same as you did but when i pressed apply then okay, the table will return back to default. It still doesn't detect the symbol '&'.
a) edited table
b) After pressed apply and okay (turn back to default)
Message 9 of 10
James_Willo
Everything is fine until you click OK....
I think maybe the only way to do this is to have it as a custom iProperty, but you'd have to replace the template file. So the '&' lives in a property rather than the table.
James W
Message 10 of 10
zakwanZKAWA
Hi, this step works for me. Thank you!
