Put symbol & in content center family table
zakwanZKAWA
zakwanZKAWA
Hi, I wanna put symbol '&' in my family table but its doesn't appear. So, is there any solution to make the symbol '&' available?
a) I want to make the table appear like this:-
b) But it appear like this:-
Replies (9)
andrewiv
Does it work if you enclose the entire string in quotes?
Andrew In’t Veld
Designer
dave.cutting
It's a control character within content centre, so it can't be used anywhere.
Dave Cutting
zakwanZKAWA
Nope. It still doesn't show the symbol
zakwanZKAWA
So, does it mean it is not possible to put symbol & in the family table?
James_Willo
If you don't use column properties you can just type it in to each cell.
I think it's because you're in the field where you create an expression and you just want a text string.
James W
Inventor UX Designer
James_Willo
Even quicker way is to just edit with excel and you can copy paste it to all the cells.
James W
zakwanZKAWA
Hi thank you for the reply!
I had done the same as you did but when i pressed apply then okay, the table will return back to default. It still doesn't detect the symbol '&'.
a) edited table
b) After pressed apply and okay (turn back to default)
James_Willo
Everything is fine until you click OK....
I think maybe the only way to do this is to have it as a custom iProperty, but you'd have to replace the template file. So the '&' lives in a property rather than the table.
James W
zakwanZKAWA
Hi, this step works for me. Thank you!
