Purpose of some components installed by Inventor?
dalic22932
Observer Observer
dalic22932
Observer
Observer
I was looking what exactly gets installed into PC when installing Inventor.
I found this list that corresponds with what I found in my PC.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Components-install...
I dont understand why are these components installed by Inventor:
  • Autodesk RSA Engine
  • Autodesk REX Framework
  • Autodesk REX Inventor
RSA is likely Robot Structural Analysis and REX is some kind of development tool for Revit extensions?
I dont understand why these get installed even if I dont use Robot nor Revit.
Any idea? Are they even required for Inventor or is this just bloat?
I also dont exactly understand Geospatial Coordinate Systems which gets pulled in by RealDWG Shared.
I guess RealDWG Shared is required for writing .dwg files if you use them instead of .idw? But Geospatial Coordinate Systems seems again like something more in line with Revit where you can actually need precise GPS coordinates. But for regular Inventor usage it seems unnecessary.
I like to install only things I need without unnecessary bloat.
So can anyone offer explanation about these components and why they arent optional?
Thanks.
johnsonshiue
Hi! Inventor has the ability to associatively import and export Revit rvt file. It is why these components are needed.
Many thanks!
Software Test Engineer
SharkDesign
What version are you running? From Inventor 2023 onwards, Revit interop isn't installed by default so in theory if these are for Revit import you wouldn't need them either.
However I've never heard of these three things so I dunno what they relate to.
  Inventor Certified Professional
dalic22932
Observer
Observer
Inventor 2026.
Try checking C:\Program Files\Common Files\Autodesk Shared
You will find those components there.
