- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello All
I am currently working on an assembly drawing for one of our machines.
I have created a main view (side elevation) and varoius projected views to show all other sides.
My plan is to show all views with hidden lines removed but not rendered.
The side view that I have created (machine left hand side) shows the parts that I want to show on the left hand side but it also shows parts on the far side of the frame that I do not want to show. I could select these lines and turn off the visability in the view but this is a mammoth job. My other option, which works quite well, is to created a section view that isn't a section view. I have placed the section line outside the machine frame and then edited the section properties from full to a distance (half way thru the machine frame), this then gives me the view I want.
My question is...is there an easier way to do this or have I hit upon the best way of doing it?
Thanks for reading
Ade
