I have a fairly large .SAT file I have received from an end user (114 MB) which was originally created in Revit. I can open the file in Inventor no sweat. My problem is that I do my pipe routing in Solidworks. When I open the file in Solidworks I get a bounding box error that the file is outside the -500m to 500m limit. I know that SW has a 1km limit however this assembly is nowhere near that size.
My question is how can I see, in Inventor, what the bounding box dimensions are and once I know what they are reduce it down. The entire assembly is about 90 feet x 90 feet, well within the 1 km limit.
Is this an issue with the model being originally created in Revit? I am completely unfamiliar with that piece of software so Im not sure if adding this bounding box is something done in Revit. According to the Revit website it will only export to these formats which is why we are using .SAT files:
CAD Formats
- DWG
- DXF
- DGN
- ACIS SAT
Any help is appreciated. Sorry for lack of attachments. Im posting for a different computer then I model on. Ill post some screen grabs later.
Edit: Im using Inventor 2018 and SW 2018
