Lofting non-parallel sketches
jacques
Message 1 of 13
jacques
Is it possible to loft two profiles that are not parallel?
Replies (12)
Message 2 of 13
SBix26
What version of Inventor, and what were your results when you tried it?
Sam B
Inventor Professional 2018.2.3
Windows 7 SP1
Message 3 of 13
jacques
Well, it depends on which way I try. The original model is extracted off Revit.
The sides are parallel but with a curve in between. If I try to loft from the side, it tells me: "The attempted loft operation had problems with the specified rail curve not being smooth. Try with a different rail or try to make the curves of the rail smooth across interior vertices."
If I try it from the ends, it tells me: "The attempted operation did not produce a meaning result. Try different inputs."
Thus the question. The curve is smooth. If I extrude each profile alone it works fine. So, the profiles are not the issue.
Message 4 of 13
jacques
B y the way, it is 2018.
Message 5 of 13
SBix26
Can you post the file here? Or at least some images (please insert them in the message - Photos button) or a Screencast video?  I doubt anyone can give a helpful answer without seeing the situation.
Sam B
Windows 7 SP1
Message 6 of 13
jacques
Here is a sample of the original revit file exported onto Inventor.
Message 7 of 13
SBix26
OK, I've got these panels open, wondering what it is you want to loft?  Re-create the existing geometry?
Sam B
Windows 7 SP1
Message 8 of 13
jacques
Recreate the geometry so that it can be manufactured as sheet metal.
Message 9 of 13
JDMather
Pretty important part of your problem description! Smiley Wink
Message 10 of 13
SBix26
These panels are curvy in ways that Inventor Sheet Metal won't flatten.
The easiest way to get a consistent thickness, though, is to use the Delete Face tool to delete the back surface and all the edge surfaces, then use the Thicken/Offset tool to thicken that surface to whatever sheet thickness you need.  But it won't flatten.
I also tried using the edges as 3D sketches to loft a surface (this technique sometimes results in a flattenable piece), but that resulting surface wouldn't thicken.
Sam B
Windows 7 SP1
Message 11 of 13
jacques
Yeah, thanks for that. I am getting the same results you described.
Message 12 of 13
JDMather
@jacques
Using MeshMixer might give you "close enough" results.
Screencast will be displayed here after you click Post.
2583d244-f4ea-4a63-9468-439873c55466
Message 13 of 13
johnsonshiue
Hi! Inventor has two flavors of Loft: Loft in part modeling and Lofted Flange in sheet metal. The former is a super versatile command taking almost all geometric types and shapes (point, line, face, edge, loop in 2D and 3D). The latter only allows two 2D sketch profiles to create a sheet metal body which can be flattened.
As JD indicated, there is indeed a workflow involving MeshMixer to unwrap any shape. See below thread for further detail. Just to let you know that we are working on a solution to unwrap faces. It is not available yet.
https://forums.autodesk.com/t5/inventor-forum/unfold-complex-surface/m-p/7249578/highlight/true#M652...
Many thanks!
Software Test Engineer
