Well, it depends on which way I try. The original model is extracted off Revit.
The sides are parallel but with a curve in between. If I try to loft from the side, it tells me: "The attempted loft operation had problems with the specified rail curve not being smooth. Try with a different rail or try to make the curves of the rail smooth across interior vertices."
If I try it from the ends, it tells me: "The attempted operation did not produce a meaning result. Try different inputs."
Thus the question. The curve is smooth. If I extrude each profile alone it works fine. So, the profiles are not the issue.
Can you post the file here? Or at least some images (please insert them in the message - Photos button) or a Screencast video? I doubt anyone can give a helpful answer without seeing the situation.
Sam B
Inventor Professional 2018.2.3
Windows 7 SP1
OK, I've got these panels open, wondering what it is you want to loft? Re-create the existing geometry?
Sam B
Windows 7 SP1
@jacques wrote:
Recreate the geometry so that it can be manufactured as sheet metal.
Pretty important part of your problem description!
These panels are curvy in ways that Inventor Sheet Metal won't flatten.
The easiest way to get a consistent thickness, though, is to use the Delete Face tool to delete the back surface and all the edge surfaces, then use the Thicken/Offset tool to thicken that surface to whatever sheet thickness you need. But it won't flatten.
I also tried using the edges as 3D sketches to loft a surface (this technique sometimes results in a flattenable piece), but that resulting surface wouldn't thicken.
Sam B
Windows 7 SP1
Using MeshMixer might give you "close enough" results.
2583d244-f4ea-4a63-9468-439873c55466
Hi! Inventor has two flavors of Loft: Loft in part modeling and Lofted Flange in sheet metal. The former is a super versatile command taking almost all geometric types and shapes (point, line, face, edge, loop in 2D and 3D). The latter only allows two 2D sketch profiles to create a sheet metal body which can be flattened.
As JD indicated, there is indeed a workflow involving MeshMixer to unwrap any shape. See below thread for further detail. Just to let you know that we are working on a solution to unwrap faces. It is not available yet.
Many thanks!
