Project file location change impact
Default workspace directory for Autodesk Inventor is D:\InvWorkDir .Currently the project file(ipj file) is also placed at the same location.Need clarification whether the project file can be moved to some other location with the workspace still defined as 'D:\InvWorkDir' within the project file.Will there be any impact due to this change during opening inventor files.
We use TCAI bulk loader to load inventor files to Teamcenter.The bulkloader tool while clearing the cache it also deletes the project file from work directory.That is the reason we want to keep the project file in some othe rlocation.
KKizildemir
Hi @Anonymous ,
When you open your project file in another path, you'll get this warning:Capture1.JPGIf you click OK, it updates the workspace path as the current path of project file. This may cause some complications.
Signature
website
emailskypelinkedinyoutubeemail
Frederick_Law
It should work.
Move the project file.
Delete the project in Inventor.
Double click the project file to open it.
Inventor will create a shortcut in the Workspace.
