Ability to select multi value parameter to populate title block thru form
bengee5454
bengee5454
I am creating a form to populate my title block. There are to be 4 separate lines of text to populate the 'Finish' box. I've created a multi-value parameter called 'Finish' to give the 4 options.
I now edit the title block to add in my parameter.........but cant find it! How can this be done?
bengee5454
I have just made it a key parameter, and can now see it......however, it doesnt add the text where it supposed to!
KKizildemir
Hi @bengee5454
Please watch the video. This may help you.
Signature
website
emailskypelinkedinyoutubeemail
bengee5454
I have tried but cannot get it to work.
To reiterate, i want to be able to select, from my title block form, one of 4 phrases - and themn my title block to show this.
I'm sure i've done something like this many years ago......
KKizildemir
Hi again @bengee5454
Now it makes sense. Please watch the video. You need to create a single line iLogic rule to run that. Here is the code:
iProperties.Value("Custom", "oCustomParameter") = oCustomParameter 'Change oCustomParameter as your drawing parameter name
Signature
website
bengee5454
That's exactly what i needed! Thank you!
KKizildemir
You're welcome!
Signature
website
