Message 1 of 10
08:47 AM
I have imported a DWG file in to Autodesk Inventor Professional 2017 successfully, however, when I create a sketch and Project DWG Geometry using the Project Connected Geometry tool on the Mini-Toolbar, inventor crashes/does not respond.
Is anyone else having this issue? And if so, is there a fix or solution to this problem?
Thank you in advance.
