Here are some of the details about Product Design Suite 2015.
http://inventortopix.blogspot.com/2014/03/product-design-suite-2015.html
@Anonymous wrote:
Nice to know Alias and Showcase can be downloaded with a PDSU; but I will sorely miss Sketchbook Designer. With its vector drawing tools it is vastly superior to Sketchbook Pro.
Hi dalibu,
You are correct that Sketchbook Pro does not support vectors. But, if you had SketchBook Designer 2014, you can use that with Alias Design 2015 or AutoCAD 2015. There's nothing preventing that workflow from functioning across those releases.
Janna
@mrattray wrote:
I don't have it yet, either.
@scottmoyse Do you use PDS or a stand alone Inventor? I suspect that us PDS users wont see Showcase up until after PDS is up.
It's probably because we have access to the standalone product license in that case.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Relative to Product Design Suite Ultimate 2015
I have been battling issues from the first day of the release of this package. Right now, it is a mess. Here's the good and bad in brief:
Showcase and Alias Design areincluded in the Suite. However, they are not in the installation pack. They must be downloaded separately. I was told, "There was a change after the launch of Autodesk Product Design Suite Ultimate that resulted in adding back the two software into the suite. However, since the change was made after the launch, they were not included in the installation pack of the suite. Autodesk is currently working on putting up the Autodesk Showcase 2015 and Autodesk Alias Design 2015 onto the downloads page of customers with valid Autodesk Product Design Suite Ultimate 2015 license."
But Showcase will likely not recognise your serial number or the PDSU product key. It will recognise the 262G1 key, but will not recognise the PDSU serial number. Alsias design will recognise the PDSU product key (781G1), and serial number. And it installs and activates correctly. Oddly, Sketchbook Pro installs with Alias Design, but will not activate with the PDSU key or serial number.
Hi jdm308,
You're right that Showcase and Alias are not part of the standard Product Design Suite installer, due to the late breaking changes discussed in this forum. Over the last couple of weeks, we have been working to create new versions of Showcase and Alias Design that will work with the existing PrDS 2015 product keys and serial numbers. The new version of Showcase will be available soon (possibly tomorrow), and Alias has already been posted.
Both products are/will be available for download from several sources:
Product Trial pages: Alias Trial Showcase Trial
Subscription center: Autodesk Subscription Center
Autodesk Accounts: Autodesk Accounts
I also talked with the Alias team, and verified that Sketchbook is, indeed, included with the Alias Design installer. Sketchbook is an optional install, but you're right, it is a little confusing.
One other note - Autodesk has expanded access to these products to all Product Design Suite 2015 customers, regardless of whether you are on subscription or not. Showcase is available to Premium and Ultimate customers, and Alias Design is available to Ultimate customers.
Thank you for providing the feedback. Please let me know if you have any other questions.
Janna
Hi Janna,
Thank you for clarifying that.
I am keeping this thread up by sharing my experience:
Installed PDSU 2015 yesterday, from my subscription account.
- Components missing (not available yet anywhere in my subscription account):
Showcase, Sketchbook Designer, Mudbox and Alias Design.
- Installation errors on some components (Back Burner):
"Error 1722. There is a problem with this Windows installer Package....Contact your support personnel or package vendor." I will.
I did not yet activate my PDSU 2015, until I had a chance to fully evaluate what's working and what's available for my subscription money.
If 30 days go by without being able to answer my evaluation questions I would have a problem. In this eventuality, I will request an extension to my trial period from my VAR and hope that they will be supportive.
Daniel
@Daniel248 wrote:
Hi Janna,
Daniel
Hi Daniel,
Sketchbook Design and Mudbox are no longer included with Product Design Suite, starting with the 2015 release. Showcase and Alias Design are now both available (I posted the locations in an earlier message), and you can activate those with your Product Design Suite 2015 product key and serial number.
I haven't seen that error message before, and I'll ask our development team to take a look.
What other questions do you have about the 2015 release?
Janna
Hello Janna,
can you tell us about the availability of the localized versions of Alias and Showcase? When will they be available?
Regards
Matthias
it shows under mine try looking under yours
DarrenP
@Anonymous wrote:
Nothing as of 30 seconds ago. I chalk it up to all the comments I've made about ADSK programmers. 🙂
It's there for me now, and chances are I said far more / worse than you about the transition between WikiHelp and AKN, and the availability of 2012/2013 help files! 😄
Rusty
Nothing has shown up in ours yet....
Not in ours yet.
Well, now I'm able to download, too.
But I'm hanging with setting up the USB delivery. No way for getting further than placing the delivery address.
No further comments
Walter
Walter Holzwarth
they are listed within PDSU 2015
are you clicking on the correct 'continue' button? i had this issue 🙂
