Problems with Ballooning
Vagulus
Message 1 of 22
Vagulus
First problem is that Auto Balloon won't work.  If I click on it I get
which does not allow view selection.
Secondly, this drawing shows four instances of Number 6.
One is the Shaft Support (Pillar) the others are a snap ring, a bearing and a circlip.
I find that a bit unusual (not to mention inaccurate).
Can someone tell me what I have done wrong?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
Replies (21)
Message 21 of 22
johnsonshiue
Hi! Please look at the screenshot you provided on post#17. The option is in the Auto-Balloon dialog.
Many thanks!
Software Test Engineer
Message 22 of 22
Vagulus
Much fiddling around later I finally get Auto Balloon to work.
It's not that hard to move the balloons and arrows.
In reference to another topic in this thread, note that the bearing and circlip associated with the round wire snap ring (7) are not tagged.  This will be because they are part of the sub-assembly of the Shaft Support (6) and are not added individually in this assembly.
Thanks all.
Albert Einstein
