Problems with Ballooning
Vagulus
Message 1 of 22
Vagulus
First problem is that Auto Balloon won't work.  If I click on it I get
which does not allow view selection.
Secondly, this drawing shows four instances of Number 6.
One is the Shaft Support (Pillar) the others are a snap ring, a bearing and a circlip.
I find that a bit unusual (not to mention inaccurate).
Can someone tell me what I have done wrong?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
Replies (21)
Message 2 of 22
jhackney1972
You need to try again and create a "complete" Pack and Go.  You are missing most of your Content Center Parts and the drawing that you are questioning.  The forum cannot replicate your issue or find a solution without a complete Pack and Go.
John Hackney, Retired
Message 3 of 22
Vagulus
There's another problem I have.  Pack-and-Go refuses to create a ZIP file.  I just run P&G to get
Old Versions
Workspace
AE-005-000.ipj
AE-005-0000.ipj.old
packngo.log
Than I zip them.
That's what you have here.
Albert Einstein
Message 4 of 22
MSD_takaseh
Hello Vagulus,
Please make sure if you choose the view before press the command.
And try to open the assembly file and "Rebuild all".
Hitoshi Takase
Message 5 of 22
Sergio.D.Suárez
the file did not fail me, but I had to delete the pieces of content center that I asked for and could not find. Be sure to select the pieces well by inserting them in the whole view, and then select the position of the balloons. Notice that the part numbers of all parts of the content center and each part of the assembly are not repeated,
regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 6 of 22
Vagulus
I assume you are talking about the Auto Balloon command.
I tried these things and the option to Select View Set is still deactivated.
Albert Einstein
Message 7 of 22
Vagulus
I am using AI 2018 with the default Content Center.  How is it that you cannot find the bearings etc.?
I don't know what you mean by "inserting them in the whole view".
Albert Einstein
Message 8 of 22
MSD_takaseh
Anyway, there are not cc components in the attached as experts mentioned.
Also please try to reset Inventor setting with the reset utility from here.
Hitoshi Takase
Message 9 of 22
jhackney1972
I made a screencast on how to include 2D drawings and presentation files, if they exist, in your assembly Pack and Go.  I know you did not ask for it but I just thought you might like to see it since you had trouble before.
Message 10 of 22
Vagulus
I did not list which components to include in the pack.  Surely that is the province of P&G.
Did that - no difference.
Albert Einstein
Message 11 of 22
Vagulus
Thanks for that.  Very helpful.
Albert Einstein
Message 12 of 22
Vagulus
I hope that this time we have all the files.
Albert Einstein
Message 13 of 22
Vagulus
I think we got it this time
Albert Einstein
Message 14 of 22
jhackney1972
Your Pack and Go was perfect!  It included everything including the 2D Drawing.  I created another screencast using the Auto Balloon feature to show you that it will not work on the smaller insert view, on the right side of the drawing.  This is because, as far a Inventor is concerned, the BOM balloons are set, after applying them to the main view.  You of course can add them manually to the right hand view.  I prefer this method anyway because Auto Balloon does such a lousy job of placing the balloon arrows.  If you use the Enter key to accept each manual balloon placement, it is a pretty quick process.
Message 15 of 22
Vagulus
Well, to my surprise, when I tried Auto Balloon again the dialog allowed me to select the view (if you check above it has not done so in the past).   Note: this time there is only a single view on this drawing.  However, when I have selected the view and my options the OK button is deactivated.
190122-AutoBalloonNoOK.pngWe are getting somewhere but not all the way.
BTW: the reason for the second view in the previous drawing (which was ballooned manually) was to allow vision of the bearing and circlip in the Support.
Albert Einstein
Message 16 of 22
Sergio.D.Suárez
I try to tell you before it is what you should select in "select location" to define the location on the drawing sheet. And previously you must select through window selection in the model view in "add or remove componets", and then the ok button will be activated.
BTW: Excuse me for my bad English, I hope to be clear
  regards
Mechanical Designer
Message 17 of 22
Vagulus
I have selected the view.
Auto-balloon simply does not want to go any further.
And, don't apologize for your English.  It's a whole lot better than my Bulgarian!
Albert Einstein
Message 18 of 22
Sergio.D.Suárez
Just where you see in the image the selection is complete, you should select placement by clicking on the icon and then clicking on the screen where you want to place the balloons
Mechanical Designer
Message 19 of 22
johnsonshiue
Hi! I am sorry if I repeat similar comments. I think you may want to uncheck "Ignore repeated occurrences" option in the dialog. Unchecking the option will ensure all balloons are unique. Does it help?
Many thanks!
Software Test Engineer
Message 20 of 22
Vagulus
Would you mind posting screenshots/video of this. I can't figure out what
you are suggesting to click on.
Albert Einstein
