Problem with flexible movement in Inventor 2023
lanUKNAP
Message 1 of 61
lanUKNAP
Hi
I hope someone can help me. I have just updated to Inventor 2023 from 2022 and I am having problems with the movement of part in my existing assemblies.
As soon as a part gets a constrain I can not move it freely in the remaining dimensions any more. If I remove the constrain again I can move the part freely in 3 dimensions.
Also all my flexible subassemblies does not work any more. They will not move.
However if I make a completely new assembly flexible subassemblies work fine and I can move part freely with one or more constrains.
What can I do so that do not have do all my assemblies all over again?
I have tried migrating the assembly and the flexible subassemblies.
I have have tried "Rebuild all".
Update: A nonsolution is if I delete all patterns in the assembly. This also affects if I make a new assembly. So I guess there is a bug where patterns and free movements and patterns cannot coexist in the same assembly.
Replies (60)
Message 21 of 61
lancermandc_co_za
I joined a Beta program many many years ago only to find out my projects I did in the beta version could not be migrated to a newer release. Last time I ever do that again....
Good luck though.....
Message 22 of 61
johnsonshiue
Hi! I am sorry I don't think that is true. We do support migrating files from Beta3 to release. In earlier Beta versions, such migration can be technically challenging.
Also, Beta builds are meant for testing purpose. You can still use it for production purpose but there is a risk.
Many thanks!
Software Test Engineer
Message 23 of 61
lancermandc_co_za
I wasn't talking about the Beta 3 program.
Message 24 of 61
Warwick_Malone
They said 1 week, 4 weeks ago.
Message 25 of 61
SBix26
Who said this about what?
Sam B
Inventor Pro 2023.0.1 | Windows 10 Home 21H2
Message 26 of 61
GJackson-GMC
It was fixed in 2023.0.1 released beginning of last week.
all is good again
Message 27 of 61
lancermandc_co_za
Correct! All is fixed with the update....
Message 28 of 61
maszynyartur
Community Visitor
Community Visitor
hi, How can i get this update?
It is not available in autodesk update center yet.
Message 29 of 61
lanUKNAP
you should be able to find it if you log into your autodesk account (accounts.autodesk.com)
under product updates. You can properly also find it in your Autodesk Desktop App.
Message 30 of 61
lancermandc_co_za
It should be in the update centre. You will have to log into your Autodesk account and go to the update centre.
[cid:7382697c-b7d3-491e-ad01-2f358622a37f]
Lance Richmond
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
his email has been scanned for viruses and malware, and automatically archived by Mimecast SA (Pty) Ltd, an innovator in Software as a Service (SaaS) for business. Mimecast Unified Email Management (UEM) offers email continuity, security, archiving and compliance with all current legislation. To find out more, visit http://www.mimecast.co.za/uem.
Message 31 of 61
bike_josh
I installed inventor 2023 yesterday and can confirm that this issue still exists even if it's not part of a component pattern. Any part within an assembly can be freely moved until a single constraint is placed on it. Once that constraint is placed, all movement is locked even though there should be free DOFs.
I am running Build 158, Released 3/7/2022 and do not have an option for any updates.
Message 32 of 61
johnsonshiue
Hi! Please install 2023.0.1 update. Does it work afterwards?
Many thanks!
Message 33 of 61
ian
I also have an issue with 2023... I have a plate with 2 holes that I can constrain holes to its mating part using MATE on the axis, but it will not let me use insert, which is what I use normally (hole centres are exact btw)
Message 34 of 61
SBix26
Please post example files.  This shouldn't happen, so there must be a rational explanation (or a geometry-specific bug).
Sam B
Inventor Pro 2023.1 | Windows 10 Home 21H2
Message 35 of 61
johnsonshiue
Hi! Do you happen to have component pattern in the assembly. If yes, that is the notorious excessive grounding bug due to component pattern in 2023. It has been fixed by 2023.0.1 update and 2023.1 update. Please install 2023.1 update.
Or, as Sam indicated, please attach the files that exhibit the behavior.
Many thanks!
Message 36 of 61
lancermandc_co_za
Correct, the latest update has solved the problem 🙂
Message 37 of 61
mohamedNAFGD
Has this been solved?  we just upgraded to 2023 and I still get the same issue.
Message 38 of 61
SBix26
Did you then apply the 2023.1 update as instructed in @johnsonshiue 's post?
Sam B
Message 39 of 61
ian
Yes the update seemed to fix the problem, thank you
Message 40 of 61
roesterling
Observer
Observer
Glad to find this thread.  I was going nuts trying to figure out what I did wrong.  The update fixed the issue.
