Problem with flexible movement in Inventor 2023
lanUKNAP
Message 1 of 61
lanUKNAP
Hi
I hope someone can help me. I have just updated to Inventor 2023 from 2022 and I am having problems with the movement of part in my existing assemblies.
As soon as a part gets a constrain I can not move it freely in the remaining dimensions any more. If I remove the constrain again I can move the part freely in 3 dimensions.
Also all my flexible subassemblies does not work any more. They will not move.
However if I make a completely new assembly flexible subassemblies work fine and I can move part freely with one or more constrains.
What can I do so that do not have do all my assemblies all over again?
I have tried migrating the assembly and the flexible subassemblies.
I have have tried "Rebuild all".
Update: A nonsolution is if I delete all patterns in the assembly. This also affects if I make a new assembly. So I guess there is a bug where patterns and free movements and patterns cannot coexist in the same assembly.
Replies (60)
Message 61 of 61
mohamedNAFGD
Which inventor release are you using?
if you go to the question mark symbol top right and click the pull down and select "About autodesk inventor"
