problem with content center libraries - Inventor 2025
wvb02
wvb02
hello all
i have a problem with content center libraries
we have been using the content center for more then 5 year thru multiple versions of inventor
and somewhere / somehow something changed with the list of libraries all the standard libraries are in red and not accessible
we are using inventor project based and no vault
and the content center files are stored on our local server
ive added a png file as how it looks
@wvb02 Your post title was modified to add the product name and version and to increase findability - CGBenner
SBix26
My first thought is that the ones in red were copied from the wrong version of Inventor, so Inventor can't open them.  Use the ones that came with this version of Inventor, which you forgot to mention in your first message.
Sam B
Inventor Pro 2026.1 | Windows 11 Home 24H2
CGBenner
@wvb02
As @SBix26 mentions, we need to see what version of Inventor you are working with currently, and also what version did those libraries come from.  There may be some incompatibility issues.  Thank you!
Chris Benner
info
we are using inventor pro 2025 and yes we have been using pro 2020 / pro 2022 before and with installing inventor pro 2025 the migrate tool was used
SBix26
The migrate tool only works on Read/Write libraries.  The installed libraries are Read Only.  You have to use the installed libraries from the version you're using; the old ones from 2022 will not work and will not migrate.
Sam B
