- Mute
- Permalink
- Report
I'm having trouble dimensioning a hole in certain a instance.
I have a drawing with a BSP socket welded over a hole in a panel. But - when I pick the hole it dimensions the hole in the BSP fitting not the hole behind it in the panel.
The actual hole line is hidden by the fitting. Is there a way around this apart from making hidden lines visible so I can then choose the correct line?
Autocad Mechanical 2023
