Inventor Forum
Problem deleting title block
5 REPLIES 5
Charlies_3D_T
468 Views, 5 Replies
Someon in the company has made a title block but when i try to delete it i get the following error:
Delete Selections: problems encountered while executing this command.
This drawing resource cannot be deleted because it is currently in use. To delete a drawing resource, first delete all references to it from drawing sheets and other drawing resources.
The problem is that i can not find out where i can find the links to this title block.
All help or tips are welcome!
Thank you
5 REPLIES 5
HAFA12
in reply to: Charlies_3D_T
If it not in use on one of the sheets in the file it might be predefined in a sheet format (under drawing resources in your browser).
Charlies_3D_T
in reply to: HAFA12
Thats the strange thing. It's not used but there has to be a link but i can
not find it.
mdavis22569
Can you share the file?
Mike Davis
Hi! I believe Hans is right. It could be used in the sheet formats. Or, there was a corruption. Please share the file here.
Many thanks!
Software Test Engineer
Hello @Charlies_3D_T !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Technology Administrators
