Inventor Forum
Problem Creating a flat Pattern from Sheet Metal
5 REPLIES 5
350 Views, 5 Replies
I am designing external louvers for a job in London, the profile as requested by the architect is made up of 3 parts. These 3 parts will then be cut from Ali sheet and welded together.
So far i have successfully completed 71/72 of the sheets but typically the last one will not create a flat pattern.
The process:
I am sweeping the 3 part profile through a radius and then trimming the ends, I then split the sheet in 2 parts (for manufacturing purposes) and then delete all other faces to leave a single part at a time, then creating a flat pattern, in essence for the part file attached, there will be 6 items all together.
Like i said, this process has worked for 71/72 sheets but refuses to create a flat pattern for this one particular item.
I have attached the part file and also one of the parts as a single item.
Any help would be much appreciated.
Anthony
5 REPLIES 5
JDMather
I would use the Sheet Metal tools to model the part.
I would dimension the first sketch.
I would set the Sheet Metal Thickness to the same as the part (actually, if the sheet metal tools had been used this would have already been set by default).
I do not see where you have even converted this to sheet metal?
Did you attach the correct file?
Also, iProperties indicates that you have not installed the Service Packs for 2016.
in reply to: JDMather
I will give that a go and let you know how I get on.
See attached part 1 converted to sheet metal.
JDMather
The last part that you attached is not converted to sheet metal.
Did you attach the correct part file - that looks like the same one attached previously?
Can you attach one of your parts that did return Flat Pattern?
See attached all 3 components, all successfully converted to flat pattern.
JDMather
@Anonymous wrote:
...See attached part 1 converted to sheet metal.
In Post #3 you made this statement.
But when I open the file and compare to one you attached that did work - I do not see the icon for a sheet metal part.
This might seem like a minor issue, but this is on top of the previously mentioned issues.
In my experience a structured modeling technique with better attention to detail usually returns expected results.
So I start to examine how this design would be done with the Sheet Metal tools in Inventor.
But as I start from scratch - when I examine one of the parts that "did work" - I observe that there are no dimensions in Sketch1?
If I dimension some of the geometry - I observe that the dimension is "perfect".  How does this happen?  Was there a dimension that was deleted?  If so, why?
