I'm assuming this will have to be a feature request, but I'm hoping someone knows something I don't. Surely I'm not the only one doing this.
I frequently design sheet metal parts for clients, and will fab the early prototypes with my own sheet metal brakes at the home shop. So when I create fab drawings, I'll create them all in 11x17 as a professional standard, but include an extra 8.5x11 "exclude from count" sheet at the end with the flat pattern I'd use for my own brake. That sheet must always print 1:1, but the others would print best fit. For this, I'm regularly changing my print settings each time I print off dwg sets before hitting the shop.
Is there any way to set my one custom sheet to default to "1:1" even if my standard print settings default to "best fit"? If not, I'm thinking my next best option is buying a bigger printer that selects feed based on page size 😞
Thanks!
