Export from Rhino to Inventor
r.rice2QLST
Message 1 of 9
r.rice2QLST
Can Rhino solids be taken into Inventor?
The model doesnt need to be parametric, a dumb solid/surface will do, it's just for a reference point to build around.
The model I need to bring into Inventor is a 3dm file.
Rob
Replies (8)
Message 2 of 9
SharkDesign
I'm assuming Rhino will export to STL with it being mesh models?
You can bring it in to Inventor as a dumb block. Some editing capability can be used but it is very limited.
  Inventor Certified Professional
Message 3 of 9
SharkDesign
To test if your file can be imported do this:
https://www.youtube.com/watch?v=Ko2U33qOGpk
Message 4 of 9
johnsonshiue
Hi! Inventor can import Rhino files (3dm) directly. There is no need to convert it to mesh.
Many thanks!
Software Test Engineer
Message 5 of 9
r.rice2QLST
I pulled the the 3dm file in and it created a .iam but it was empty. Have I missed a step?
Rob
Message 6 of 9
SharkDesign
Are you on the most up to date Inventor? It's possible if your 3dm file is a newer version that your inventor install can support you might get a blank file or an error.
Post your file here if you are stuck.
Message 7 of 9
r.rice2QLST
No, attempted with 2019, shall try with 2022 and revert back.
Thanks!
Message 8 of 9
JDMather
Can you zip and attach example files here (*.3dm *.stp *.stl)?
Message 9 of 9
mgb228
Hi, not sure if you're still looking for an answer to this- but for me I had to import the Rhino after I opened the Rhino file. Your situation may be more complicated than this, but as a first time Inventor user this was what I had to do to merely see my Rhino geometry in the viewport.
