I like to know how to indicate a contact between components in a pressure vessel, specifically between door and ring, should they have a fixation or a separation contact? thank you very much.
Rene Vanhaecke
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Thanks, i like to know if i have to use a bonded contact when two parts are in contact and totally sealed (internal pressure) but not welded. Greetings.
@Anonymous
Just out of curiosity, how is this sealed? Is there a gasket between the ring and the door? How does this work? ( look cool to me ) and what kind of pressure vessel is the pipe?
