Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Inventor Forum
Pressure vessels in tension analysis (FEA)
4 REPLIES 4
433 Views, 4 Replies
I like to know how to indicate a contact between components in a pressure vessel, specifically between door and ring, should they have a fixation or a separation contact? thank you very much.
Rene Vanhaecke
4 REPLIES 4
Binga
Hello Rene.
Welcome to the Autodesk Community.
I don't know your design intent, but if you use the Bonded Contact, the parts will act like they are just one part.
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
in reply to: Binga
Thanks, i like to know if i have to use a bonded contact when two parts are in contact and totally sealed (internal pressure) but not welded. Greetings.
P.S. In this case a door for a vessel and his locking device.
Jef_E
@Anonymous
Just out of curiosity, how is this sealed? Is there a gasket between the ring and the door? How does this work? ( look cool to me ) and what kind of pressure vessel is the pipe?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
