pressed plate
pressed plate
pressed plate
The attached part is a pressed aluminium plate.I would have preferred to use the shell tool but i could not get success so used extrusions. I added the fillets first followed by the shell but no success. Can the shell tool be used here for this part?
Best Regards,
James
INV2015
JDMather
Have you installed Service Pack 1 and Update 2?
Your part is not uniform thickness?
Also - you didn't have any draft on the sides.
