Advanced search could use the ability to require all words, but not in a specific phrase.
Anyhow is anyone else having issues migrating presentation files to 2017.
I seem to get this type of thing, the first picture is the assembly with the representation selected. The second is the IPN, showing the representation is associative, and not shown, but the slider is all the way to the left, so no tweaks should be showing. The top extrusion actually doesn't even get tweaked. I have not found anything that will make it sync up to the assembly.
Solved by johnsonshiue. Go to Solution.
Odd indeed.
Possibly time to create a new view for the IPN and log a issue with ADSK
Hi Kent,
It looks like a bug to me. Could report a defect to the support team or send the files to me directly (johnson.shiue@autodesk.com)?
Many thanks!
Thanks Guys. Johnson, I sent it to you. The attachment is 6+MB so let me know if it doesn't go through.
Johnson found some issues in, my PosReps, I am going to mark this as solved, although I think there is still a issue with the PosReps not showing as being used in the Explosions.
