Hi all,
We're looking at purchasing Inventor (to upgrade from out 2015 version). I also use Fusion 360 for CAM occasionally. Would it be possible to add Inventor CAM at a later date or should we just get a Fusion 360 subscription instead? We don't need the full PD&MC suite as we don't use AutoCAD at all. Thanks in advance.
Solved by mcgyvr. Go to Solution.
Inventor CAM isn't available on its own..
There is a small price benefit into doing just Inventor and Fusion vs PDMC..
If you have absolutely no need for anything else in PDMC then you can save a little bit getting Inventor and Fusion CAM standalones
