as you can see I have a little problem with my project.
Maybe someone can help me to fix the problem.
Best Regards
Solved by CCarreiras. Go to Solution.
Hi
Turn off center of gravity visibility on the View tab.
Kacper Suchomski
Hi!
I believe it is a matter of (wrongly) showing the center of gravity of all the pieces.
Try this:
1. Go to the "Manage" tab and click the "Rebuild All" button
2. Then click the "Update Mass" button
3. Save and select "Save all referenced" parts
4. Close and reopen the assembly
Hi! Go to Manage -> Rebuild All -> Save -> Close and Reopen. Are they gone?
Many thanks!
