Plane of iPart does not update to correct position in Assembly
klemen_zivkovic
klemen_zivkovic
I have Autodesk Inventor 2015 update 2, and I created iPart, that has "Work Plane 51", that is defined by xz plane and point in sketch that is driven by parameters.
When I select active row in iPart plane is updated accordingly.
When I put iPart to Assembly, plane is updated correctly only in one instance out of 4 - how is this possible?
That drives me realy crazy - because it seems like it is inconsistent behaviour.
See attached screenshots and whole iPart.
in iPart plane moves apropriately picture below with row 1 of table selected.
when I put those iParts to assembly I get this:
The strange thing is that sketches and other planes move correctly... Smiley Frustrated
autodesk-MM
Planes are in the correct position. Unfortunately the plane view across the parts stays frozen as per last active member position.
Last active member is on the top, two planes are 27mm offset from the end faces-, (yes- all in the table, would not appear if its not...) when you scroll across the ipart factory everything is ok and travel with the part, but when you place an ipart in an assembly, planes stay frozen as per last active member.
Autodesk, its almost 2017 I am running inv pro 2016 build 236 sp2 and the problem still exists.
Would be great if solved, but this is at the end of the list when comes to ipart/iassembly errors.
klemen_zivkovic
Autodesk,
can we get official explanation why is this happening and if you plan to addres this in next patch?
This would really benefit iAssembly usefulness...
