When creating a drawing in Inventor, how do I set the default dimension (and leader note) text height so it doesn't change?
First the information I'm providing to you should be done in your Inventor (drawing) template..
Under Manage/Styles Editor.. Define your dimension styles and then under Object Defaults, change the filter to dimensions and define your style to the dimension annotations.
Also because I don't like changing the out of box styles in my template and causing a styles conflict between the drawing and the information in the design data.. This is how I would recommend setting of your styles in your drawing (https://synergiscadblog.com/2015/10/20/avoiding-style-conflicts-completely-inventor-drawings/)
Mark Lancaster
& Autodesk Services MarketPlace Provider
Ok, thanks for your comprehensive reply
