Placing X_T files into Inventor
rellisEVKA9
Message 1 of 32
rellisEVKA9
I have received .x_t files and I want to know how to correctly place it and turn it into a part file.
Do I need some type of converter like a Parasolid?
I am in an assembly file......in the middle of "Placing Imported CAD Files". I can see the status bar at 95%, and it's gradually placing .ipt files in the folder I created for it.
Obviously, I am doing something wrong. Must be a simpler way
Rick
Accepted solutions (4)
Replies (31)
Message 21 of 32
rellisEVKA9
Took care of it a month ago
Never posted that I figured it out
Message 22 of 32
My school is using the professional 2018 version of inventor,
Message 23 of 32
SBix26
OK. The file I opened yesterday is version 2019, so you won't be able to use it.  I'll try it in 2018.
Sam B
Inventor Pro 2020.0 | Windows 7 SP1
LinkedIn
Message 24 of 32
SBix26
Success with Inventor 2018, too.  I've uploaded the file to A360.  Note that it is one part file containing 1429 solid bodies.
By the way, the file would be noticeably smaller if the creator hadn't engraved the vLTm logo on every single piece of this model, which is actually Lego® parts...
Sam B
LinkedIn
Message 25 of 32
Thank you so much! I appreciate you taking time out of your day to help me with my school project.
Message 26 of 32
is there a way to convert an assembly file to a part file?
Message 27 of 32
SBix26
Shortest route is to derive the assembly into a part file: start a new part, then used the Derive tool; Derive allows you to choose which components are included as well as a number of other options.
You might also try Shrinkwrap or Simplify.
Sam B
LinkedIn
Message 28 of 32
sandra_kirby32
Community Visitor
Community Visitor
I am trying to convert this X_T file to an inventor file by bringing it into Inventor and then saving it as an inventor file but it only loads to 37% and then stops and causes Inventor to crash. I tried changing my file to a step file but it loaded this screen I have never seen before, please see the screenshot below.
I am using Inventor 2024
The file is 89,330 KB
Message 29 of 32
johnsonshiue
Hi Sandra,
The behavior is usually file specific. Please share the file with me directly [email protected]. I would like to understand it better. In the meantime, please try viewing it on viewer.autodesk.com. Does it work?
Many thanks!
Software Test Engineer
Message 30 of 32
g.w.collingwood
I have opened an x_t file in Inventor and now have an Assembly file.
However, two of the included files are "surface models" and I cannot 3D print them.
Is it possible the convets the "surface models"to solid models.
Thanks for your help.
Message 31 of 32
SBix26
In theory, yes.  But it depends very much on why the parts didn't get saved as solids.  If they're missing some faces, then you'll have to create the missing faces, which can range from very simple to extremely complicated.  If you can post the files here, somebody will either do the job for you or show you how, or tell you that it's not worth the vast amount of work involved.
Sam B
Inventor Pro 2025.2.1 | Windows 11 Home 24H2
Message 32 of 32
g.w.collingwood
Thank you for your reply.
I have attached the two files as requested.
Cheers
