Does anyone know how to place your first part in a assembly so that the origin of the first part is at the origin of the assembly?
Thanks!!
Solved by TheCADWhisperer. Go to Solution.
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
In tools application option assembly tab.. Select the option to place and ground first component at assembly
Mark Lancaster
& Autodesk Services MarketPlace Provider
...or you can Right Click when Placing and select Place Grounded at Origin.
