Inventor Forum
Place part Right click Menu?
7 REPLIES 7
Message 1 of 8
weslie_howard
507 Views, 7 Replies
When I go to place a component into an assembly I use the right click context menu to rotate the part as necessary. What I would like to know is it possible to customize this menu? What I would like to do is change or add different degrees of rotation on X, Y and Z.
Thanks for any help.
Tags (2)
7 REPLIES 7
Message 2 of 8
Hi Weslie,
I could be wrong but I am not aware of a way to configure that particular right-click context menu.
Many thanks!
Software Test Engineer
Message 3 of 8
salariua
in reply to: weslie_howard
Johnson is never wrong, except on purpose.
The intended functionality here is to aid in placing component but this tool is intended to place components and precise position and orientation should be done with joints, constraints, grip snaps, etc.
If you need precise rotation without constraining then investigate Grip Snap.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 4 of 8
kelly.young
@weslie_howard Did the previous posts help you with your problem? Please select the Accept as Solution button if a post or posts solves your issue or answers your question so other community members may benefit. Thanks!
Message 5 of 8
Thanks Everyone for your suggestions. It looks like this menu is not customizable.
Message 6 of 8
eschmtz
I have an issue with placing parts with the right click menu rotations.   Before I place the part, I have it oriented as I want, but when I click to place, it places it different that the view.
I have closed Inventor and reinstalled, but the issue remains.
Thoughts??
Message 7 of 8
JDMather
in reply to: eschmtz
It probably would have been best to start a new thread and provide link back to this thread for reference.
Do you know how to use assembly constraints?
Message 8 of 8
kelly.young
Hello @eschmtz I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
This was logged this a few weeks ago, it might be relevant.
Use last occurrence orientation for component placement preview does not update
Hope that helps.
Please select the Accept Solution button if a post solves your issue or answers your question.
