& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Hi
When I create a route in pipe and tube environment, the cursor did not show the dimension when I drag the cursor.
See the image below, Please let me know how to make visibility.
Rgds
Can you show a screenshot of your issue... Are you go further than the route line? @cbenner any other thoughts?
I was think of heads up display is not enabled but since you never indicated the HUD is not working while sketching I assumed that was ok.
Mark Lancaster
& Autodesk Services MarketPlace Provider
In your image, the dimension IS showing. When you route, do you not see this? Do you see an "X" on the sketch guideline? If so, check your Tube & Pipe style and see what your minimum pipe length is. Sketch dimensions on a route will not show up until you drag the mouse to at least the minimum allowed pipe length.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Are you using Inventor 2019.2? I just did it with that version and I no longer see the dimension either..
@cbenner are you using Inventor 2019.2?
Mark Lancaster
I am not on 2019.2 yet. Heard there were too many bugs.
Chris Benner
Tagging @johnsonshiue on this one for investigation.
Mark Lancaster
Hi Mark and Chris,
If I understood OP's question correctly, it is about the ability to see the length display when the cursor is outside of minimum length axis. It seems to be a designed behavior. I guess the minimum length in the active Tube&Pipe Rule is too small. You may want to increase the minimum value to a greater value. So, the minimum length axes are longer.
Regarding the bugs in 2019.2, every release and every update have bugs. But, somehow the perception of quality differs. Some vocal users here claimed that every release and every update were worse than the prior ones. But, we have quite a few large customers stay current moving to 2019.2 without issues. 2019.3 update just went live today. It should address most of the known regressions in prior updates.
Many thanks!
Hi Team,
Please see the attached image here !
When I move the cursor green dot only appears but dimension is not shown ?
Is it correct As I shown the image, when do routing the other components visibility is not usual, as shown below !
I do not know what is the meaning of HUD ?
Rgds
Hi
I am using Inventor version 2019.1
Rgds
Hi Kiri,
I am sorry I misunderstood your request. I think the length display is controlled by HUD option. Go to Tools -> Application Options -> Sketch -> Heads-Up Display -> check "Enable Heads-Up Display."
Many thanks!
Although I'm not disputing the HUD settings (which I thought was the case in the beginning), there seems to be an issue here in Inventor 2019...
As you can see my T&P style min dim is 2in
When I start my route (centerline), you can see no dimension is shown. In the past at least in Inventor 2018 the route node placement the dimension was shown.
As you can see my node placement is more than 2in
And the application options regarding HUD are enabled.
If I go back to Inventor 2018 and use the same T&P style the routing node dimension shows up
Mark Lancaster
Hi Johnson,
I just checked it is enabled !
I stripped Inventor 2019.2 --> 2019.1 --> 2019 (testing between each stage) and the routing node dimension never appears like in Inventor 2018.
@cbenner are you using Inventor 2019?
Mark Lancaster
Hi Mark,
Thanks for your response !
Already every thing is enabled.
Rgds
Hi
I just installed inventor 2019.3, but I just wonder why it is not show in the list below ?
Rgds
From what I read in the readme for Inventor 2019.3, there's internal issues that's been fixed and there's nothing new for this release.
Mark Lancaster
Hi
1. I have tried with inventor 2018 version it works well and it automatically shows the value during route.
2. When I try an exercise from Ascent I found that Select other snap is not working and the inventor freezing for few seconds in 2019.
Need to be fixed !
Regards
Hi Guys,
I am using 2019.2 and 2019.3. I am not seeing the issue regarding the length dimension display on creating a new route. I need to take a closer look.
Many thanks!
Hi Johnson,
How I can overcome this problem ?
Rgds
Release 2019.1.1 Build 200
I still see dimension following my cursor as I am routing. See below: Is this what you are looking for?
Chris Benner
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
