Pipe and tube route dimension
lkirit2000
lkirit2000
Hi
When I create  a route in pipe and tube environment, the cursor did not show the dimension when I drag the cursor.
See the image below, Please let me know how to make visibility.
Rgds
Replies (36)
Mark.Lancaster
@lkirit2000
Can you show a screenshot of your issue...  Are you go further than the route line?   @cbenner any other thoughts?
I was think of heads up display is not enabled but since you never indicated the HUD is not working while sketching I assumed that was ok.
Mark Lancaster
cbenner
@lkirit2000
In your image, the dimension IS showing.  When you route, do you not see this?  Do you see an "X" on the sketch guideline?  If so, check your Tube & Pipe style and see what your minimum pipe length is.  Sketch dimensions on a route will not show up until you drag the mouse to at least the minimum allowed pipe length.
Mark.Lancaster
@lkirit2000
Are you using Inventor 2019.2?    I just did it with that version and I no longer see the dimension either..
@cbenner are you using Inventor 2019.2?
Mark Lancaster
Mark.Lancaster
Tagging @johnsonshiue on this one for investigation.
Mark Lancaster
johnsonshiue
Hi Mark and Chris,
If I understood OP's question correctly, it is about the ability to see the length display when the cursor is outside of minimum length axis. It seems to be a designed behavior. I guess the minimum length in the active Tube&Pipe Rule is too small. You may want to increase the minimum value to a greater value. So, the minimum length axes are longer.
Regarding the bugs in 2019.2, every release and every update have bugs. But, somehow the perception of quality differs. Some vocal users here claimed that every release and every update were worse than the prior ones. But, we have quite a few large customers stay current moving to 2019.2 without issues. 2019.3 update just went live today. It should address most of the known regressions in prior updates.
Many thanks!
Software Test Engineer
lkirit2000
Hi Team,
Please see the attached image here !
When I move the cursor green dot only appears but dimension is not shown ?
Is it correct As I shown the image, when do routing the other components visibility is not usual, as shown below !
I do not know what is the meaning of HUD ?
Rgds
lkirit2000
Hi
I am using Inventor version 2019.1
Rgds
johnsonshiue
 Hi Kiri,
I am sorry I misunderstood your request. I think the length display is controlled by HUD option. Go to Tools -> Application Options -> Sketch -> Heads-Up Display -> check "Enable Heads-Up Display."
Many thanks!
Mark.Lancaster
@johnsonshiue
Although I'm not disputing the HUD settings (which I thought was the case in the beginning), there seems to be an issue here in Inventor 2019...
2018-12-17_21-32-22.jpg As you can see my T&P style min dim is 2in
2018-12-17_21-32-51.jpg  When I start my route (centerline), you can see no dimension is shown.   In the past at least in Inventor 2018 the route node placement the dimension was shown.
2018-12-17_21-33-03.jpg  As you can see my node placement is more than 2in
2018-12-17_21-33-29.jpg And the application options regarding HUD are enabled.
If I go back to Inventor 2018 and use the same T&P style the routing node dimension shows up
Mark Lancaster
lkirit2000
Hi Johnson,
I just checked it is enabled !
Mark.Lancaster
@johnsonshiue
I stripped Inventor 2019.2 --> 2019.1 --> 2019 (testing between each stage) and the routing node dimension never appears like in Inventor 2018.
@cbenner are you using Inventor 2019?
Mark Lancaster
lkirit2000
Hi Mark,
Thanks for your response !
Already every thing is enabled.
Rgds
lkirit2000
Hi
I just installed inventor 2019.3, but I just wonder why it is not show in the list below ?
Rgds
Mark.Lancaster
@lkirit2000
From what I read in the readme for Inventor 2019.3, there's internal issues that's been fixed and there's nothing new for this release.
Mark Lancaster
lkirit2000
Hi
1. I have tried with inventor 2018 version it works  well and it automatically shows the value during route.
2. When I try an exercise from Ascent I found that Select other snap is not working and the inventor freezing for few seconds in 2019.
Need to be fixed !
Regards
johnsonshiue
Hi Guys,
I am using 2019.2 and 2019.3. I am not seeing the issue regarding the length dimension display on creating a new route. I need to take a closer look.
Many thanks!
lkirit2000
Hi Johnson,
How I can overcome this problem ?
Rgds
cbenner
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
