Inventor Forum
pinned and unpinned files
9 REPLIES 9
Message 1 of 10
1287 Views, 9 Replies
The problem is files pinning and unpinning and even duplicating gon the home screen. This is the first time for it to be happening. I checked and old thread that mentioned that the Inventor profile/registry entry is corrupted, messed up or you don't have the proper permission to write to it. How do I fix this?
9 REPLIES 9
Message 2 of 10
I figured it out, it was a registry error. Unfortunately, I lost all my pinned files from a current project. Is there a way to get them back without opening each individual file (over 100)?
Message 3 of 10
-niels-
-niels-
Nice that you figured it out!
If you had to clear your registry to fix it then i don't think there is an easy way to get them back.
You can open multiple files at once... if you make your recently used list amount high enough, you could open all / most of your files and then pin them as needed....?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Niels van der Veer
The Netherlands
Message 4 of 10
in reply to: -niels-
I'm not worried about it. I've started and stopped this particular project so many times I know it inside and out.
Message 5 of 10
mdavis22569
mdavis22569
Are you using more than 1 IPJ by chance?
Have you tried that?
Mike Davis
Mike Davis
Message 6 of 10
in reply to: mdavis22569
Why would more than 1 IPJ make a difference?
Message 7 of 10
mdavis22569
mdavis22569
The workspace changes generally ...
Here is a quick Screencast showing it change:
https://autode.sk/3e0r1NM
https://knowledge.autodesk.com/community/screencast/3263e29b-0a85-40ef-be1f-b60e7dfcb1fe
Mike Davis
Mike Davis
Message 8 of 10
Okay, I understand that part of this topic, but I'm having the same problem again after repairing the registry. This is very weird.
Message 9 of 10
mdavis22569
mdavis22569
What are you using for an Anti-Virus / Firewall?
I think we've talked on a prior question about having Admin rights on the PC yes?
Is this a work or personal PC?
Mike Davis
Mike Davis
Message 10 of 10
I'm using Norton 360 for antivirus and the firewall. I have admin privileges and my computer is a personal one.
