Pin Pressing simulation- Static or dynamic
gopinathmY575P
Message 1 of 8
gopinathmY575P
Hi Team, i need a documentation or tutorial link for pin pressing simulation it may be static or dynamic for the below case.
thank you in advance.
Replies (7)
Message 2 of 8
admaiora
I'm not sure what your objectives are.. If you want to simulate the actual pin pressing process, I wouldn't start with a dynamic analysis. It is mainly a quasi-static nonlinear problem, since it involves contact, sliding, and above all geometric interference.
An explicit dynamic analysis would make sense if the insertion occurred very rapidly, for example by impact or hammering.
Admaiora
_____________________________________________________________________________
Message 3 of 8
johnsonshiue
Hi! I believe this needs to be done in Dynamic Simulation environment. It is because the links are movable and they are not stationary.
Many thanks!
Software Test Engineer
Message 4 of 8
gopinathmY575P
Noted. Any tutorial link to experiment that in Autodesk inventor?
Message 5 of 8
gopinathmY575P
Actually, its pin pressing application, which involves contact, sliding, and above all geometric interference. not exactly as you mentioned sir.
Message 6 of 8
admaiora
https://help.autodesk.com/view/NINCAD/2026/ENU/?guid=GUID-DB7160BE-0C72-47B9-B5EF-FC4925B455CE
https://help.autodesk.com/view/NINCAD/2026/ENU/?guid=GUID-78221AC2-E5B1-4F92-ABA7-3276C35DCA60
https://help.autodesk.com/view/NINCAD/2026/ENU/?guid=GUID-F0AEC491-0C7C-4C18-964F-94D5698298D9
Admaiora
Message 7 of 8
hollypapp65
Your picture show pin bending.
Pressing will be pushing pin into the block.
Message 8 of 8
mluterman
don't forget to check for buckling.
