Perforated sheet
I have a situation where i wish to create a perforated steel sheet and then fold or unfold it in the sheet metal tool.This perforated steel sheet is 2 mm thick with 4 mm holes at a specific triangular pitch.
To creat the geometry is not a problem ,the problem arises because the number of holes runs into the thousands, this has the effect of slowing down the computer quite considerably.
I know it is possible to increase the performance but i doubt as to whether this will make much difference.
I have tried to create a pattern of so many holes and then create or duplicate this pattern hoping to reduce the memory usage but this does not work.
Is there another way that this can be achieved by using blocks,or some other method.
The system i am using is inventor professional 13,computer has 32 GB RAM.
Any suggestions please.
Ps Analysis of the final tube with holes needs to be carried out to prove its structural integrity.
