Inventor Forum
Perforated sheet
5 REPLIES 5
2744 Views, 5 Replies
Perforated sheet
I have a situation where i wish to create a perforated steel sheet and then fold or unfold it in the sheet metal tool.This perforated steel sheet is 2 mm thick with 4 mm holes at a specific triangular pitch.
To creat the geometry is not a problem ,the problem arises because  the number of holes runs into the thousands, this has the effect of slowing down the computer quite considerably.
I know it is possible to increase the performance but i doubt as to whether this will make much difference.
I have tried to create a pattern of so many holes and then create or duplicate this pattern hoping to reduce the memory usage but this does not work.
Is there another way that this can be achieved by using blocks,or some other method.
The system i am using is inventor professional 13,computer has 32 GB RAM.
Any suggestions please.
Ps Analysis of the final tube with holes needs to be carried out to prove its structural integrity.
5 REPLIES 5
mcgyvr
Don't model the holes and adjust the material properties (youngs moduli,etc..) as necessary to achieve acceptable results..
mpatchus
in reply to: mcgyvr
Agree with mcgyvr, adjust your material properties for your analysis.
If you need a more realistic visual representation, adjust the color style.
Use the Screen_5&.bmp texture, or create one of your own that more closely resembles your hole pattern.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
PaulMunford
Whoops - sorry. I accidentally clicked on 'accept as soloution' instead of kudos (I'm on my phone).
However I agree with the above. I would add, for anyone who is looking for patterning tips; if you create a feature with a hole in it and pattern the feature, the result seems to take less memory than patterning a hole.
And you could always create as big a pattern as you can. Then 'Step' it out, and bring it back in and pattern the dumb solid.
Autodesk Marketing Manager D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
in reply to: mcgyvr
Thanks for the reply mcgyvr. Without complicating the issue,when you say alter the youngs modulus is there a specific formula. If we assume the sheet is solid ie without perforations and made from carbon steel and then we punch holes in the sheet in which manner does this affect the youngs modulus,ie to what degree of percentage is it reduced by. Surely the size of holes must have an impact if this approach is used. What I am trying to do is to create a rolled perforated tube ,then load the top edge with the bottom edge constrained to see what happens to the tube under compression and to see the deflection along the axis. Regards
mpatchus
Take a look at this link....  Strength and Elastic Properties of Perforated Metal
They describe the "Equivalent Solid Material Concept" for design analysis of perforated metals.
Not sure how detailed your analysis has to be, but it might be something you can use.
Inventor 2025 Beta
