Patterning Features along a path defined by sketch or swept solid
jatin_sanskrit
jatin_sanskrit
Please refer to the attachments. One attatchment is the figure which I am trying to model as a part, and other is the part that I have managed to model till now. Here I want to pattern the "Extrusion 1" and "Extrusion 2" based on a sketch path, or a swept solid. The number of pattern needed is "20". Can I create such a pattern of 20 objects of these extrusions?
JDMather
@jatin_sanskrit
Your Sketch2 has a error.
Examine these Tangent Constraints (is there a zero length line)?
What is the purpose of Extrusion2 cut?
Later you filled the hole with Join of Sweep.
Did you Intend for these to be different bodies?
@jatin_sanskrit
Examine the Attached file.
jatin_sanskrit
@JDMather
Sorry for my late reply. The design posted in the question is a part of an exercise book intended to get a practical experience on Inventor for beginners. I have attached a file with this reply that outlines what the student is expected to do for the exercise. Please suggest your approach in relation to the exercise.
Jatin Kulkarni.
kacper.suchomski
Look at this video:
(view in My Videos)
Kacper Suchomski
jatin_sanskrit
@kacper.suchomski
Cool. That solves my problem.
JDMather
@kacper.suchomski
Curved hole or straight hole on bodies on curved portion of Sweep body? 🧐
kacper.suchomski
@JDMather  At the moment it is simple, which follows from the sequence - duplicating a specific CNC detail
You can also duplicate the full profile and create a matching cutout using the Borowska operation. Then we will get different elements.
Of course, you can also decide whether you want it in one solid body or in separate ones.
Kacper Suchomski
