Revision Cloud - Behind text box
pmaxwellNKJEX
pmaxwellNKJEX
I'm trying to put a revision box around some changes in a text box, but the revision cloud is pushed behind the text box. Example below.
Is there a way to fix this?
I couldn't see anything like "bring to front" or similar.
johnsonshiue
Hi! I am sorry I must not have followed the steps correctly. I cannot seem to reproduce the behavior. Could you share the files here? I would like to understand the clipping behavior better.
Many thanks!
Software Test Engineer
pmaxwellNKJEX
Please see file attached.
There's not much to it;
Create a text box in an .idw then place a cloud around some text within that text box.
Below is what I see in the attached file.
johnsonshiue
Hi! Many thanks for sharing the file! I was on our latest internal build. Actually, the clipping function isn't working, which is a bug. I am not aware of an option to disable the clipping option. I need to check with the project team to understand the behavior better.
Thanks again!
