Inventor Forum
Pattern hole along irregular shape
3 REPLIES 3
789 Views, 3 Replies
I have an irregular tapered lofted shape (see attached) and I am trying to create patterned holes all the way round in four rows (see attached drawing). The shape is hollow and the holes must go through to the inside surface. I apologise if this is simple but I can't work out how to do it! I am new to the forum and would appreciate some guidance.
Kind Regards,
Luke
Kind Regards,
Luke
3 REPLIES 3
Cadmanto
Cadmanto
Take a look at this thread and see if it helps you with what you are trying to do.
https://forums.autodesk.com/t5/inventor-forum/component-patterning-along-a-curve/td-p/8105108
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Inventor Pro 2020
Best Regards,
Scott McFadden
JDMather
JDMather
While you wait for someone to take a look at your file - I recommend that you install Update 4 for 2019.
johnsonshiue
johnsonshiue
Hi! This should be fairly straight forward. You need to create multiple parallel workplanes from the top or the bottom. Then create a 3D Sketch > Intersection Curve -> pick the work plane and the Loft body. These curves can be used for patterning. Create one of the hole. Then use Rectangular Pattern command -> select the hole -> select the 3D curve as direction. Please feel free to attach your attempt, if you cannot figure it out.
Many thanks!
Software Test Engineer
Many thanks!
